S1 Sticky front brakes
ALAN COCHRANE
#1 S1 Sticky front brakes
Post by ALAN COCHRANE » Fri Aug 21, 2015 4:56 pm
Hi Everyone
On my last long run I noticed that the car was pulling to the near side under medium braking. The car came fitted with the Coopercraft "Zeus" callipers at the front.
I found that the lower outer piston on the driver's side was stuck. This tied in with the symptoms I had experienced.
I ended up replacing all four pistons, seals and dust covers
in the calliper and at the same time fitted new braided flexible hoses to both sides.
Unfortunately the problem persists. Surely the new pistons can't have stuck as well. Thoughts please.
Alan
Alan Cochrane
1954Etype
Post by 1954Etype » Fri Aug 21, 2015 5:52 pm
Pads. Try swapping them over and see if the problem moves.
Angus 67 FHC 1E33656
61 OTS 875047
ALAN COCHRANE
Post by ALAN COCHRANE » Sat Aug 22, 2015 3:36 pm
Angus
Go to the top of the class. With the pads swapped over the E now has a rather unnerving habit of wanting to meet the oncoming traffic head-on. So I've had a seized piston and contaminated pads simultaneously. What are the chances of that.
What would you suggest as the best replacement pads. I have the Coopercaft Zeus callipers.
Thanks Again
Alan
Alan Cochrane
David Oslo
Norway
Post by David Oslo » Sat Aug 22, 2015 4:43 pm
Think Angus is already top of the class :D
David
S2 OTS '70 (arriving)
Post by Heuer » Sat Aug 22, 2015 4:48 pm
I use Greenstuff pads in my Zeus calipers - work very well.
1954Etype
Post by 1954Etype » Sat Aug 22, 2015 5:10 pm
Depends on driving style. If you dont drive it hard, the standard pads are fine. Greenstuff are great but can glaze if not pushed hard enough.
We have just sorted the brakes on a s2 2+2. Long pedal and no bite to the brakes at all. Everyone had had a go at bleeding the brakes to no avail. Turned out the rear outer pistons had seized and the fronts were sticking. Rebuilt calipers all round and new pads (replaced the greenstuff) and the eldetly, long term owner is delighted.
61 OTS 875047
ALAN COCHRANE
Post by ALAN COCHRANE » Sat Aug 22, 2015 5:40 pm
I've had Greenstuff pads in the GT6 for many years and I agree they're first rate. Do I order the Greenstuff pads for the 3.8 or. 4.2 or is it another size entirely for Zeus calipers?
Alan
Alan Cochrane
Post by Heuer » Sat Aug 22, 2015 6:02 pm
You need the ones for the S2 E-Type (larger curved. not the small rectangle used on the S1's): http://tinyurl.com/p7cjhv2
rolando38
Post by rolando38 » Sat Aug 22, 2015 6:54 pm
I'm also replacing my pads (only to realize I also had a seized piston I'm tackling), with Greenstuff
Was delighted on my oher cars (Mk2, Stag) , but I often had to grind the edges a little bit (1/10th mm) to ease them in
2+2 1970
ALAN COCHRANE
Post by ALAN COCHRANE » Sun Aug 23, 2015 6:19 pm
Well Greenstuff it is. Ordered today from EDC.
Thanks for the link David.
Any idea what yellowstuff pads are like?
Alan
Alan Cochrane
Post by Heuer » Sun Aug 23, 2015 8:16 pm
Not for a road car - too extreme!
