Does anyone know if the top and bottom heater motor oilight bearings are
avaliable from any one ?
heater motor bushes
#2
Try Ashley Hinton he makes and refurbs Smiths heater motors 01372 456304.
Adam
Adam
Depends if it is a Smiths or AC-Delco motor.
#4 heater motor bushes
How do you tell which make it is there are no numbers or name on mine ?
You read the Factory Fit thread, very carefully
: viewtopic.php?p=43520&highlight=delco#43520
The Delco casing has eight support slots in the lower casing which look a bit like the vents on a 250GTO. It has a diameter of 2 3/4 " compared to 3" for a Smiths. Bud Marston and I have been corresponding over this and here are a couple of his photos:
Smiths motors were usually printed as such on the base in white/red paint or had a sticker on the body with part number in the format FHM xxx/xx. Smiths also usually used a metal fan wheel rather than nylon. The Delco Remy motors are unmarked (although there may be a seven divit part number stamped on the top) and use a nylon fan. If you want new bearings you need to look at GM product.
My current project is to understand where the Delco - Smiths Industries divide occurred but for the moment I think it is fair to say all 3.8's and 4.2's should have the Delco motor and nylon fan. Unfortunately the Delco blowers were troublesome so many have been replaced. If anyone has one on a S2 4.2 please let me know what year.
So mine isn't an original then?
http://www.grainedevie.ch/restaurations ... 427520.jpg
Oh, I found it on the web. It's a VDO (never heard about that brand)
http://www.stockwiseauto.com/product_in ... id/1780245
1E35547
Hi David
I have a Delco with Nylon wheel on my 02/1970 S2. Hope this helps
Alban
Alban
Alban
E-type S2 2+2, 3 Weber’s, O/D gearbox
Range Rover Classic 1987
