a arm drive shaft sizes
frenchi
#1 a arm drive shaft sizes
Post by frenchi » Thu Sep 10, 2015 5:53 am
is there a page or has someone got an a arm from rear axle as i have s type xjs arms and drive shafts but i need an e type measurment from one end of tube to the other can some one help thanks
Simonpfhc
Post by Simonpfhc » Thu Sep 10, 2015 6:38 am
Hi Frenchi,
I've just taken a quick measurement from my IRS which is still out of the car. The distance between the two shafts that locate the arm to the diff and hub is exactly 42cm from shaft centre to shaft centre. I can get you the exact tube length later this evening if you want.
Cheers.
62 3.8 FHC
91 Porsche 928GT
David Oslo
Norway
Post by David Oslo » Sat Sep 12, 2015 8:07 am
Well done Simon !
My car's in the paint shop otherwise I would've popped out and measured to help Frenchi. Better with a tape measure than keyboard advice.
David
S2 OTS '70 (arriving)
