#1 a arm drive shaft sizes
Posted: Thu Sep 10, 2015 5:53 am
by frenchi
is there a page or has someone got an a arm from rear axle as i have s type xjs arms and drive shafts but i need an e type measurment from one end of tube to the other can some one help thanks
Posted: Thu Sep 10, 2015 6:38 am
by Simonpfhc
Hi Frenchi,
I've just taken a quick measurement from my IRS which is still out of the car. The distance between the two shafts that locate the arm to the diff and hub is exactly 42cm from shaft centre to shaft centre. I can get you the exact tube length later this evening if you want.
Cheers.
Posted: Sat Sep 12, 2015 8:07 am
by David Oslo
Well done Simon !
My car's in the paint shop otherwise I would've popped out and measured to help Frenchi. Better with a tape measure than keyboard advice.
