#1 Tappet noise conundrum
Posted: Tue Sep 29, 2015 8:02 pm
The engine had always sounded a bit tappety so have taken the opportunity of re-shimming the tappets but still have noise.
Fitted new long skirt cam followers and bought a couple of (good second hand) later camshafts which reports suggest should be quieter than the early cams even when they are properly shimmed.
After a couple of trial fittings and buying new shims got them all at 12 thou gap except no. one exhaust at 13 thou. As the later cams are supposed to be 12-14 thou inlet and exhaust felt all was good. Checked the camshaft timing and that is bang on. Didn't bother with the valve guide hold-down kit as all the guides were solid with no marks or anything to suggest they were loose. Everything torqued down correctly.
Sadly on start up still got a tappet sound, a fairly steady single note not multiple cylinders.
Frustration!
Took the covers off while the engine was still warm (run for 2-3 minutes) and checked the clearances (will do it again cold tomorrow) and most now showed 13 thou with two or three at 14, but nothing over.
Any thoughts?
Does a loose valve guide sound like a noisy tappet?
What does a loose/tight upper cam chain sound like?
I've heard suggestions to set these cams at 10-12 thou inlet and 12-14 outlet, any comments?
I did trial fit the cam followers to get cosy fit on each.
Frustration!
Any thoughts?
