#1 wiper park cable
Posted: Mon Nov 09, 2015 4:45 pm
by adam
Hi, can anyone tell me if you can fit the wiper park adjuster cable to the rack when its already in the car, or do I have to drop the rack or remove the rack.
Adam
Posted: Mon Nov 09, 2015 7:55 pm
by Alty Ian
It can be fitted in the car but it is very fiddly and you need small hands :lol:
Posted: Mon Nov 09, 2015 9:06 pm
by adam
Thanks also trying to work out how it attaches to the rack. Mine did not come with one, got one from Richard Smith.The end of the cable sits on slotted part on rack body where does L shaped clip fit on to.
Adam
Posted: Mon Nov 09, 2015 10:45 pm
by Alty Ian
Unscrew it as far as you can using the knurled nut, it clips onto the top of the rack with the spring between the two parts and then you tighten the knurled nut and it compresses the spring and pushes the two parts together which adjusts the parking position.
Posted: Mon Nov 09, 2015 11:21 pm
by adam
Thanks I will give that a try.
Adam
Posted: Tue Nov 10, 2015 12:59 pm
by ChrisC
Let me know how you get on Adam - Its one of the very few things on my car that post rebuild I could never get to work. But I have got quite good at turning off the wipers at the right moment :)
Posted: Tue Nov 10, 2015 8:18 pm
by adam
Found the problem, PO had screwed finger swipe arm to the rack frame! :evil:
Perhaps without the cable he wanted to keep the arm out of the way. Spent 3 hours being James Herriott now I know the problem will finish job when I take car off the road, when the salt hits!
Posted: Wed Nov 11, 2015 1:52 pm
by Polse7317
May be it can help you.....
Posted: Wed Nov 11, 2015 6:33 pm
by adam
Thank you that is just what I needed.I had searched every where for close up pictures.That why the forum is such a great help,People making time to help someone out.
Adam
