Post
by cactusman » Sat Jan 02, 2016 8:28 am
Mgcjag beat me to it. One probe to thread and one to the screw term on the top where you connect the wire. Room temp look for around 600 ohms plus or minus 50 ohms depending on how hot your room is. Drop in a mug of boiling water for a minute, fish out while hot, dry with kitchen roll and immediately re test. You should see somewhere around 80 to 200 ohms I would guess depending on how hot. Don't burn your fingers!!!!
I will almost guarantee it does work...thermistors are pretty reliable. If it does indeed work th n suspect either the gauge or reg. The gauge, as described above, has a small heating coil that warms a bimetallic strip that bends and moves the needle. Measure the resistance of the meter between the spade terminals. I would imagine it will be somewhere around 10 to 50 ohms. If the weather is not too not to dismal I will measure mine. If your meter is open circuit....high resistance then the coil has failed. I would imagine someone somewhere could mend but may be simpler to get a replacement. They do turn up on a well known auction site quite frequently!!
