#1 Fitting the Crankshaft rear rope seal
Posted: Wed Jan 06, 2016 1:40 pm
I am helping out on a couple of winter projects, one on a 3.8 XK150 and the other on a 4.2 Series II E type.
We are working on the re-building the 3.8 engine first and then will tackle the 4.2 engine. We are presently starting the re-assemble the 3.8 engine and assessing the fitting of the rear crankshaft rope seal. Some articles mention soaking the seal in oil overnight before installation, but others appear to show the seal being worked into position "dry". Our supplied seals are white in colour and "dry", but am I confusing dark coloured seals in some articles as perhaps a different form of supply - such as pre-impregnated with an additive such as graphite ?
I understand the requirement to tap the seal on the sides to narrow the section and then slowly roll it into the groove using a round bar, but I am confused as at what point is it then soaked overnight in oil. Is it then removed after pepping and trimming to be soaked as I would be concerned that any fitment would be changed once it was oil soaked ? What is the purposes of the holes at each end of the seal sections ? Do pins need to be inserted into these holes ?
One interesting web article by "Vintage Vehicles" shows a photo at the end of the installation process once the two halves are clamped around the crank where seal shows an imprint of crank spiral groove to confirm full contact all around the journal. I then read another article which states that when using the Jaguar sizing tool, (JD-17) that there should be a 1 to 2 thousands clearance between the seal and the crank.
So plenty of well meaning advice out there, but I would prefer to hear from our group of their experiences of how they installed the seal to work effectively.
regards,
regards,
