Jaguar XJ6 S2 inlet manifold - cooling hoses fit
JD-JAG66
Italy
#1 Jaguar XJ6 S2 inlet manifold - cooling hoses fit
Post by JD-JAG66 » Thu Jan 21, 2016 5:40 pm
Hello,
Has anybody tried fitting a late XJ6 S2 4.2 inlet manifold? Late means fitted with HIF7 carbs.
If so, I would love to hear on which coolant hoses you used where? I guess that I can use the original C24579 hose between manifold water outlet and header tank. But I get the impression that I have to blank off the radiator bottom hose outlet on the xj6 manifold.
Cheers.
