#1 Rev counter drive and cam shaft
Posted: Sat Feb 27, 2016 10:59 am
by Spark
Help please
My car came without a Rev counter generator fitted
I has acquired one and the drive adaptor ( should have checked cam shaft )
When I came to fit and the cam shaft isn't threaded for the drive.
What options apart from getting new cam shafts ( do I need a pair?)
Or get it machined? So it fits, will this alter balance.
Or can I drive the Rev counter from another source
Posted: Sat Feb 27, 2016 11:02 am
Easiest solution is to get the tacho converted to a modern circuit board and fit the generator as a dummy.
Posted: Sat Feb 27, 2016 11:04 am
by Spark
Do you have any details how to swap this
Ta
Posted: Sat Feb 27, 2016 1:22 pm
by PeterCrespin
I fitted the internals from a Series 3 XJ tach. Fiddly but not complicated, then run from the coil impulses.
Posted: Sat Feb 27, 2016 4:33 pm
by Moeregaard
I'm with Andrew and Pete. The tach generator is a pain in the neck.
#6 Tacho generator
Posted: Sat Feb 27, 2016 6:25 pm
by cactusman
There is an excellent thread on here about converting your voltage driven tacho so the cam generator just provides an engine speed dependent ac frequency to drive the tacho. I have converted mine. Works a dream. Bit of electronic knowledge is all you need....and be able to etch a PCB helps...
Posted: Sat Feb 27, 2016 9:43 pm
Spark wrote:Hi
Ta
If you're in the UK send it to Speedograph Richfield in Nottingham.
If you're in the US Mike Eck (jaguarclock.com) does them as well.
I have used both
Posted: Sun Feb 28, 2016 7:09 pm
by Spark
If I swap the Rev counter to electronic can you let me know how it's wired up to the gauge
Posted: Sun Feb 28, 2016 9:15 pm
by Spark
Sorry just need the help
