ignition switch
nick2012
#1 ignition switch
Post by nick2012 » Sun Mar 06, 2016 11:46 am
I have replaced the steering/ignition lock on my S2 2+2 with the S3 version as this is apparently all that is available now.Can anyone advise the correct wiring to the existing loom.The new switch has more wires and different colours attatched. They are fitted with a multi plug at the end which i am prepared to remove.Please do not suggest I look at the wiring diagrams they do not help.Thanks Nick
#2 Re: ignition switch
Post by PeterCrespin » Sun Mar 06, 2016 1:26 pm
nick2012 wrote:I have replaced the steering/ignition lock on my S2 2+2 with the S3 version as this is apparently all that is available now.Can anyone advise... Please do not suggest I look at the wiring diagrams they do not help.
Since a quick glance at the wiring diagrams side-by-side, not only 'helps' but more or less immediately shows what goes where, it seems odd that I'm not allowed to refer you to them, but you're the boss.
MarekH
Post by MarekH » Sun Mar 06, 2016 2:11 pm
Dear Nick,
If you are unable to make a truth table for both switches or understand the correlation between wire colour to function then pay somebody else to do this job.
