tilting dolly
bosman
Netherlands
#1 tilting dolly
Post by bosman » Fri Mar 18, 2016 12:42 pm
Not sure if this idea is new here or not, but I thought I'd show it anyway, it may be of help to some. To be able to work on the bottom side of my E Type (removing old paint and rust-protection), and also be able to move it around my garage, I made a simple "dolly" that suits both needs. I made two small separate dollies, both made from steel square tubing with some coaster wheels, and with uprights that bolt onto the body. Than I made two "side-arms" of one size smaller square tubing, that can be inserted into each dolly, on either side of the car. Because of the design, the car can than easily be tilted on it's side, manually, by one person. Very easy. And when it's on it's wheels, with the side arms removed, there's nothing in the way for the body guy to do his work. No need for any bolts or other connection to attach the side-arms, they simply slide in and out.
Maybe it's old news and has been done a thousand times, in that case, please ignore my post. But it's very simple and works well for me!
Good luck, Arjen
265bhp
Post by 265bhp » Fri Mar 18, 2016 1:16 pm
Nice....
Pim
Netherlands
Post by Pim » Fri Mar 18, 2016 2:05 pm
Very clever
Pim van der Schaaf
1E34261
1A33630BW
ManniB
Post by ManniB » Sat Mar 19, 2016 1:06 pm
Arjen,
great idea! When tilted on it's side, can you drag it along the floor? I have no idea how heavy the body is! The space in my garage is limited so when tilted sideways, I would need to drag it into the middle of the avalable space.
Thanks, Manfred
bosman
Netherlands
#5
Post by bosman » Sat Mar 19, 2016 2:42 pm
Hi Manfred, the bare shell is not very heavy, I estimate around 150 kg, so with a little effort you can drag it around when it's on it's side.
Arjen
AMR
#6
Post by AMR » Sat Mar 19, 2016 6:57 pm
Very interesting 8)
Eric
860160 january 1962
paulsco
Post by paulsco » Sun Mar 20, 2016 5:54 pm
Excellent idea!
Too late for me though; I built a much more complicated wooden rotisserie.
Had I seen this first I would have done this.
