#1 Secondary Throttle Body Worn Spindles
Posted: Fri Mar 18, 2016 8:01 pm
by vern jones
Hi I have a 69 e type that I bought from California early this year. Would love to convert to triple SU if possible if I can find a set and I do have a wanted ad here to see if I can get a set. But until that time I have a dilemma with my one worn and one broken secondary throttle body spindles. What are my options do I.
The engine runs a tad of on idle and light throttle.
Remove the spindles and tap and plug the bush.
Try and obtain some second hand spindles which will no doubt be worn as well.
Or is there other alternatives. Hope to hear something back.
Many Thanks
Vern
Posted: Fri Mar 18, 2016 10:00 pm
Hi Vern.....must be quite a few strombergs around spare from outhers who have already done what you want to do....in the wanted section i have a Stromberg advertised its from a V12 , not sure if its any use....
Posted: Sat Mar 19, 2016 12:17 am
by vern jones
Hi there having read posts it appears they are different to carbs. Not keen on the Strombergs so don't want to spends loads on fixing them rather spend on SUs.
Posted: Sat Mar 19, 2016 1:33 am
by PeterCrespin
Tap and plug is fine. Epoxy a plug in is also fine. Runs worst at idle because that's the highest vacuum, along with light cruise. You can slip in a length of thin wall 2" tube if I remember correctly, which blanks off the passages as well as the spindle holes.
Posted: Sat Mar 19, 2016 10:43 pm
by vern jones
Thanks for that advice, Mine already runs rough at idle and on light throttle so was hoping it would cure that. I am going to try plugging them and see how I get on. Have looked at SNG and they have two SU conversion one around 3000 and the other around a 1000 more. Any idea of why the price difference.
Posted: Sat Mar 19, 2016 11:32 pm
You need to give more details of what they are offering....like a link to both options
Posted: Mon Mar 28, 2016 2:43 pm
by jme
I have many difficulties with my secondary throttle and I did it
Image :D
Posted: Mon Apr 04, 2016 10:05 pm
by vern jones
Hi the sleeves look real good. I plugged the ends and refitted it. Runs so much better now. Still love some SU's mind.
