Running problem
jaime
#1 Running problem
Post by jaime » Sun May 10, 2009 12:52 pm
I have tried jaglovers on this but still no joy, I start my car via (jump leads) as battery has become dead because of problem, starts fine every thing works fine then after 5 or so mins the voltage gauge, petrol gauge drop like no power, the horn stops working, then the engine starts misfiring and will not rev then finally dies, If I wait a while it'll start again and process will start again.
Thanks in advance
Jaime :roll:
Post by Heuer » Sun May 10, 2009 1:06 pm
Jamie
My guess is your problem is electrical and is one or more of these:
1. Battery failing to hold charge, so faulty
2. Alternator diodes failed producing no charge
3. Voltage regulator faulty
Let us know what year and model of E-Type and what steps you have taken so far to diagnose/eliminate the problem and we can go from there. An E-Type will only run whilst there is sufficient charge in the battery to power the ignition system. A flat battery means the car will stop.
jaime
Post by jaime » Sun May 10, 2009 1:42 pm
Hi David,
Im going to replace battery today, no seperate VR as within alternator
the wiring going in to the alternator is a bit weak so will replace that as well, although the alternator isn't that old but could be faulty.
I'll post an update later
james
'67 FHC 4.2
jaime
Post by jaime » Sun May 10, 2009 4:26 pm
:lol: Right I replaced the battery and renewed the spade connection on the alternator and no problem hurrah!, although I still wait to see if it charges fine, the voltage gauge says normal. So thank you :lol:
jaime
Echezeaux
Post by Echezeaux » Mon May 11, 2009 12:15 am
AMAZING !!!!
Problem posted on Sunday at 12.52 pm , problem solved by Sunday 4.26 pm.
You guys are certainly more efficient than my mechanic !! :shock:
Thierry
3.8 RULES
I want to die peacefully in my sleep, like my grandfather,not screaming and terrified like his passengers.
