#1 Positive ground to negative ground on 3.8 OTS
Posted: Sun May 10, 2009 9:37 am
by Echezeaux
I want to go, positive to negative ground on my S1 3.8.
Lots of it has been talked about on other forums, somewhat in contradictory manners !! But I wonder if you need to swap connectors on the instrument voltage regulator ?
Has someone on this forum been down this path ?
I am scared of sparks and smoke !!
Thanks in advance.
Thierry[/b]
Posted: Sun May 10, 2009 11:34 am
by 1954Etype
Thierry, do a search on the Jag Lovers site. This topic has been well documented there and I believe you might even find a step by step guide as to what to do.
Posted: Sun May 10, 2009 11:42 am
There is a link to the step by step guide in the 'Recommended Specialist's' thread but here you go: http://www.jcna.com/library/tech/tech0023.html
Providing your car is standard (i.e. no after-market changes) it is a simple job. The radio causes most people the biggest grief.
Posted: Mon May 11, 2009 12:08 am
by Echezeaux
Thanks for your help, I have been through those posts before, but I will read them again and let you know if I fried something or not !!
Thierry
Some times later....
:oops: The JCNA post answer my question quite clearly, I need new spectacles !!
Thierry
