#1 Running problem
Posted: Sun May 10, 2009 12:52 pm
by jaime
I have tried jaglovers on this but still no joy, I start my car via (jump leads) as battery has become dead because of problem, starts fine every thing works fine then after 5 or so mins the voltage gauge, petrol gauge drop like no power, the horn stops working, then the engine starts misfiring and will not rev then finally dies, If I wait a while it'll start again and process will start again.
Thanks in advance
Jaime :roll:
Posted: Sun May 10, 2009 1:06 pm
Jamie
My guess is your problem is electrical and is one or more of these:
1. Battery failing to hold charge, so faulty
2. Alternator diodes failed producing no charge
3. Voltage regulator faulty
Let us know what year and model of E-Type and what steps you have taken so far to diagnose/eliminate the problem and we can go from there. An E-Type will only run whilst there is sufficient charge in the battery to power the ignition system. A flat battery means the car will stop.
Posted: Sun May 10, 2009 1:42 pm
by jaime
Hi David,
Im going to replace battery today, no seperate VR as within alternator
the wiring going in to the alternator is a bit weak so will replace that as well, although the alternator isn't that old but could be faulty.
I'll post an update later
james
'67 FHC 4.2
Posted: Sun May 10, 2009 4:26 pm
by jaime
:lol: Right I replaced the battery and renewed the spade connection on the alternator and no problem hurrah!, although I still wait to see if it charges fine, the voltage gauge says normal. So thank you :lol:
jaime
Posted: Mon May 11, 2009 12:15 am
by Echezeaux
AMAZING !!!!
Problem posted on Sunday at 12.52 pm , problem solved by Sunday 4.26 pm.
You guys are certainly more efficient than my mechanic !! :shock:
Thierry
