Stromberg piston lift
doffo25
#1 Stromberg piston lift
Post by doffo25 » Tue May 03, 2016 12:27 pm
Im (still1) trying to diagnose a starting fault on my 73 series3 ots which has been standing for years. I have (fresh) fuel pressure, compression, and fat sparks. It wont fire but will splutter if I spray fuel into air intakes. The plugs remain dry. Its a US spec so has lots of emissions pipework and Im wondering if there is a vacuum leak.
My main question is: On cranking the engine, should the carburettor pistons lift?
Thank you
David
David Offord
1972 Series3 ots
#2 Re: Stromberg piston lift
Post by abowie » Tue May 03, 2016 10:14 pm
There should not be enough vacuum to lift the pistons just cranking it on the starter. They will sit flat down on the bridge with the car idling.
doffo25
Post by doffo25 » Wed May 04, 2016 9:04 am
Thanks Andrew thats all I needed to know
best
David
David Offord
1972 Series3 ots
