#1 Replacing points - mystery part
Posted: Sat May 14, 2016 1:31 pm
Hi all
In the process of replacing the points in my S1 E-type with a Pertronix electronic ignition kit. I've removed the distributor cap and wire from the coil and then unscrewed the points to remove. However I was expecting to thread the cable through a hole to remove the points and condenser but I have a separate plastic shroud that everything is connected to that has a spade connector point (see pics)
Is this a standard part or after market? It looks to us that we don't need the part at all so can someone please advise
Any help much appreciated
Trev
Trev
