Post
by Heuer » Tue May 12, 2009 10:59 am
Odd as sidelamps should be on F5, indicators on F7 and ignition on F6. The Hazard lights are on a separate fuse F4 so that is why they are working. Is the car original or has it been rewired by someone? If it is correct then the problem lies between the fuses and the battery.
I suggest you start by going through each and every electrical item (all ancillaries, lights including all warning lights, interior etc, dash lights, heated rear screen etc etc) and make a list of what is faulty. This should help point to a fuse block or common connector. Do you have a decent wiring diagram (preferably in colour) to work from? If not PM me your email address.
