#1 Door seal glue; I'm trying something different this time
Posted: Sun May 22, 2016 10:23 pm
I'm finishing the reassembly of my S1.5 after having it painted.
I'm reinstalling all of the rubber body seals.
I've done this job several times now on different cars, and in the past I've used contact adhesive. I find correctly positioning the seals impossible with the damn stuff. The moment the 2 glued surfaces touch they stick and this makes trying to get the rubbers into channels beyond me.
This time I'm going to try using a "normal" glue that you put on wet and let dry. I'm going to go with E6000; "Goop" in the USA.
What I've done so far is position the seals perfectly using a few tiny blobs of Superglue.
Then what I plan to do is to lever the seal back and apply the E6000 between it and the bodywork. Then I'll shut the doors and leave the car for 24 hours for the E6000 to set.
I've had to order the glue online as it's not available locally.
I'll let you know how it goes.
