It seems my 4th gear switch comes alive very early, at the slightest moovement of the gear lever.
I thought to adjust it a bit by putting a washer under it so it sits more proud of the cover.
Correct idea ?
I have fitted and wired an OD, so I really want to be sure it's activated in 4th gear only, not along lateral lever moovement.
Carsten
How to adjust the 4th gear switch ?
#1 How to adjust the 4th gear switch ?
My OD switch has a fibre washer between it and the top cover.
Ian
Ian
E-type - TBC
1968 Triumph GT6 Mk1
Iirc I have one copper washer found and re-fitted.
I'll try 2 washers next- and report back.
Carsten
Carsten
