#1 rubber on torsion bar shields and LH mudshield and handbrake aperture!
Posted: Sat Jul 02, 2016 1:51 pm
by mark10337
I got replacement torsion bar shields and a LH mudshield as mine were all missing. From the parts catalogue there are meant to be rubber strips along one side of each of them. I have the rubber, I just can't see how to attach it to the shields. The wheel arch rubbers are riveted with the strips, but these I can't work out.
Any pictures anyone or guide?
Also, the handbrake lever aperture seal BD20469. It goes on the underside of the console, but no obvious way of attaching. simply glued?
#2 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Posted: Sun Jul 03, 2016 4:09 am
I thought I was the only person in the world with torsion bar shields!
From memory and paleontological examination of my original shields there was a strip of what actually looked like braided cotton military harness webbing maybe 2" wide that goes between the shield and the engine frame it's fixed to. I think the idea was to stop it rattling.
I never fitted any replacement. The shields rattle annoyingly.
#3 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Posted: Sun Jul 03, 2016 4:10 am
WRT the handbrake rubber; yes it is glued on. It will therefore fall off later.
#4 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Posted: Sun Jul 03, 2016 7:47 am
Hi Mark.....I have the shields on my S2 2+2 and as Andrew says there was a webbing type material fitted.....mine are back on the car but no rubber fitted
#5 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Posted: Sun Jul 03, 2016 11:24 am
by nefematic
Mark,
it wasn't rubber, it's a woven/braided textil band. I believe mine to still be original (but dirty) at least they are there. Doing stuff on the front end I took my shields off and cleaned them, I think the bands were glued to the shields bur are also held somewhat by the brackets as well. See in the pic upper right corner. My shields were bent, I straightened them out before reassembly, the pic is before work done.
Martin
#6 Re: rubber on torsion bar shields and LH mudshield and handbrake aperture!
Posted: Sun Jul 03, 2016 11:43 am
by nefematic
Mark,
I found another picture of the original band. A bit dark, look closely. The bottom textil band is what I sourced as a substitute for one side.
Martin
