#1 Tightening the upper timing chain
Posted: Thu Jul 07, 2016 6:26 pm
by jagwheels
Hi Lads. I have a bad rattle from the upper timing chain and went to tighten it and the locking plunger on the adjustment that tightens the chain was stuck. It tapped in easy but I cant get it out now. Any idea on how to get it out now.
Regards John
#2 Re: Tightening the upper timing chain
Posted: Thu Jul 07, 2016 10:00 pm
It'll often stick if there is tension on the chain. Wiggle the vernier wheel back and forth until it pops out.
If you can't budge it loosen the chain and remove the lock nut, lock washer then the vernier wheel, Be careful not to drop them into the sump. BE aware that the plunger is spring loaded and has nothing to restrain it once the wheel is off, so keep a finger on it to stop it shooting out as well. Then you can gently release it and put it all back together again.
#3 Re: Tightening the upper timing chain
Posted: Fri Jul 08, 2016 4:30 pm
by jagwheels
Thanks Andrew I will give that a go
#4 Re: Tightening the upper timing chain
Posted: Sat Jul 09, 2016 6:09 pm
by jagwheels
So I took it apart and the plunger still stuck solid. Discovered it would move in a circle so I got a grips on it and moved it from left to right and worked it out after about 30min of struggling with it.
#5 Re: Tightening the upper timing chain
Posted: Sat Jul 09, 2016 6:16 pm
Hi John......is the spring in there.....
#6 Re: Tightening the upper timing chain
Posted: Sat Jul 09, 2016 7:05 pm
by jagwheels
Yes the spring was there it was just stuck fairly solid and I should not of taped it in, Once out and cleaned works fine.
#7 Re: Tightening the upper timing chain
Posted: Sat Jul 09, 2016 9:39 pm
Excellent!
Always a bit scary when you take that nut off...
#8 Re: Tightening the upper timing chain
Posted: Sun Jul 10, 2016 6:46 am
by jagwheels
Yes it would be very easy to drop one of the bits in to the engine. Thanks
