Cheating heater demister hoses ?
Durango2k
#1 Cheating heater demister hoses ?
Post by Durango2k » Fri Aug 12, 2016 10:02 pm
Mine are all loose (5 small pieces), to short, hardened and do slide out of the dash top vents.
Any cheap way to cheat here ? 1.5 mtrs is 20 Euros- must I really buy this new ? Thought about using short parts of a bike tyre tube, but maybe someone has a better idea ?
It's invisible and a not-really-necessary part in the end...
Carsten
#2 Re: Cheating heater demister hoses ?
Post by mgcjag » Fri Aug 12, 2016 10:43 pm
How about self amalgamating tape...it bonds to iitself http://www.screwfix.com/p/self-amalgama ... 0wodAmUNiA
Durango2k
#3 Re: Cheating heater demister hoses ?
Post by Durango2k » Sat Aug 13, 2016 6:04 am
...doubt it would be cheaper.
Methought about toilet paper rolls (the innards), but they're too weak. (Just jokin' a bit here...).
Seems I bite the bullet and buy the real thing from SNG.
Problem is just I am again, after the long african holiday trip, a bit broke, so progress on the car stops a bit due to missing items- you all know that.
And I am sooo close to close the dashboard.... Paper tubes on top, and harduras below, thats all.
Then seats, final carpets, interior: job done.
Similar in the engine bay - fit exhaust, fit starter motor cable, fit carbs, fill up, trial run time...
Carsten
#4 Re: Cheating heater demister hoses ?
Post by mgcjag » Sat Aug 13, 2016 8:14 am
Hi Carsten.....my thoughts were for you to use some tape on the small tubes that you have that are loose.......use it on each end around the tubes to slightly reduce the diameter......anyway good news on tne car not long to go
Moeregaard
#5 Re: Cheating heater demister hoses ?
Post by Moeregaard » Sat Aug 13, 2016 3:11 pm
I used CAT ducting, available through aviation suppliers. It's not expensive and far more durable than the paper stuff.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
64etype
#6 Re: Cheating heater demister hoses ?
Post by 64etype » Sat Aug 13, 2016 3:50 pm
I found some vacuum cleaner /Hoover hoses in the correct diameter at a repair shop.
Eric
kingzetts
#7 Re: Cheating heater demister hoses ?
Post by kingzetts » Sat Aug 13, 2016 8:43 pm
I used some black pvc ribbed tubing intended for use in garden water features and aquariums.
Like this http://www.pondkeeper.co.uk/subcat.asp?SubCatID=19
Has worked perfectly for 7 years.
John '62 S1 OTS (now sold)
Simonpfhc
#8 Re: Cheating heater demister hoses ?
Post by Simonpfhc » Sun Aug 14, 2016 12:16 pm
Hi Carsten,
I've just bought a 2m length of hose on ebay. It is advertisied as fish tank hose and is really cheap. This is the item number 370770201732. The size you need is 32mm and it was £6.75 with free postage. It's corrugated like the original, but made of plastic so won't fall apart like the original! It is nice and pliable and fits perfectly ;-)
Cheers.
62 3.8 FHC
91 Porsche 928GT
JagWaugh
Switzerland
#9 Re: Cheating heater demister hoses ?
Post by JagWaugh » Sun Aug 14, 2016 12:33 pm
I've had pretty good luck with a local place which sells and maintains campers and all of the various bits associated with them. The place here in Zurich has a selection of sizes in paper, stainless, plastic, Aluminum and other materials.
Andrew
mark10337
Switzerland
#10 Re: Cheating heater demister hoses ?
Post by mark10337 » Sun Aug 14, 2016 1:53 pm
damn, I just ordered some from XKS in the US. Where is the place in Zurich?
-Mark
