My rear discs are retained by nyloc nuts - seems to me that this is potentially too hot for this type of locking nut. Wikipedia says 121 DegC maximum. Is there any authoritative view on this? What are Barrayts etc supplying if you order them? I would have thought wired nuts would be the way to go here.
Nyloc Nuts rear discs
Steve Marshall
Topic author - Posts: 180
#1 Nyloc Nuts rear discs
#2 Re: Nyloc Nuts rear discs
Use Philidas nuts (locking nut with metal not nylon)..... http://www.sngbarratt.com/AlternativeIt ... 454076040f
#3 Re: Nyloc Nuts rear discs
I second Steve's point. The discs get significantly hotter than 121 Deg C. Philidas or Metaloc are required. Same at the front for the Hub/Disc fasteners.
Andrew
Andrew
#4 Re: Nyloc Nuts rear discs
Knew those nuts had a special name....I agree with the others....avoid nylons.
shauniedawn
#5 Re: Nyloc Nuts rear discs
Also search for 'Aerotight', 'Binx', 'Steel lock' and 'Steel insert lock' nuts.
Sample website: click here
Shaun
Shaun
E-type 3.8 FHC Flat Floor
860868
860868
