#1 Rear light under riders
Posted: Sat Aug 20, 2016 9:37 am
by Bernie2015
Hi all, I have bought chrome under riders for the rear lights on my series 2 but cant work out how they fit. There is a place for a bolt to be screwed into the under rider itself but cant work out how it fits to the lamp unit - any help much appreciated.
#2 Re: Rear light under riders
Posted: Sat Aug 20, 2016 9:44 am
Whats an under rider?
#3 Re: Rear light under riders
Posted: Sat Aug 20, 2016 10:02 am
by iani
I expect Bernie means the finisher, BD35741, there is a cutout behind the light, the bolt passes through this and screws into the finisher.
Ian
#4 Re: Rear light under riders
Posted: Sat Aug 20, 2016 12:18 pm
by Bernie2015
Thanks Ian yes its BD35741, I can't see a cutout behind the light could you point me in the direction of a diagram or photo somewhere
#5 Re: Rear light under riders
Posted: Sat Aug 20, 2016 12:27 pm
Have a look here Bernie took me 1min with a google search
http://www.jagexp.com/phorum/read.php?4,11987
#6 Re: Rear light under riders
Posted: Sat Aug 20, 2016 1:25 pm
by Bernie2015
Thanks but it doesn't show what the long securing bolt attaches to on the body of the car before screwing into the finisher
#7 Re: Rear light under riders
Posted: Sat Aug 20, 2016 1:51 pm
by iani
Having searched a few parts catalogues, this bracket doesn't seem to be listed anywhere. On my car, it is a U shaped bracket, welded onto the rear valance, it sits behind the light mounting panel, the U section is around 1" long and item 39
http://www.sngbarratt.com/CatalogueProd ... 887&a=7617 is supposed to sit on the inboard side of the bracket, you then do the bolt up to hold the part in place.
#8 Re: Rear light under riders
Posted: Sat Aug 20, 2016 2:29 pm
Hi Bernie....did you look through all tne link i gave....the 2nd photo shows the head of the long bolt fitted in tne bracket that Ian explains above
#9 Re: Rear light under riders
Posted: Sun Aug 21, 2016 9:15 am
by Bernie2015
I think I need the 'u' shaped bracket mentioned but I can't find it listed anywhere. All I can see in the second photo is the head of the self tapping screw Im afraid.
#10 Re: Rear light under riders
Posted: Sun Aug 21, 2016 9:24 am
by Bernie2015
Had to join the Jaguar Experience forum so can see the photo now thanks. It seems I need that 'U' shaped bracket to fix bolt through which I cant find.
#11 Re: Rear light under riders
Posted: Sun Aug 21, 2016 9:31 am
Hi Bernie...the brackets are welded on...i suppose u could probably rivet or screw them on....try Hutsons they have lots of body panels Try to find a photo on a bare shell from tne rear ps the chrome finisher is also known as a Clam shell
#12 Re: Rear light under riders
Posted: Sun Aug 21, 2016 12:41 pm
by Bernie2015
Many thanks Steve
#13 Re: Rear light under riders
Posted: Fri Aug 26, 2016 8:34 pm
by mark10337
I have been having great difficulty getting the reinforcing washer - Part 39 on the SNG diagram
Without it I can't mount the finisher either. Has anyone got a source for this, or dimensions?
#14 Re: Rear light under riders
Posted: Sun Aug 28, 2016 1:17 pm
by iani
Mark,
If you have the U shaped bracket, you only need a washer that will sit behind that and allow the bolt to pull the finisher in tight.
If you don't have the U shaped bracket, you really need a photo from someone who has a car with the rear end partially dismantled, I'd suggest approaching Angus, if he doesn't have one now, he no doubt will have soon.
Neither the bracket nor the washer would be difficult to fabricate, you just need some pics and dimensions.
Ian
#15 Re: Rear light under riders
Posted: Tue Sep 13, 2016 12:39 pm
by Bernie2015
I have the bolts and washer now but access is proving very difficult to tighten up . Any tips?
#16 Re: Rear light under riders
Posted: Tue Sep 13, 2016 3:18 pm
by mark10337
No tips except perseverance I'm afraid. Where did you manage to source the washer from or did you get one made? Could you let me have the dimensions before you finally bolt it on?
#17 Re: Rear light under riders
Posted: Tue Sep 13, 2016 5:33 pm
by Bernie2015
Its down at the garage but next time Im there will measure it
#18 Re: Rear light under riders
Posted: Tue Sep 20, 2016 12:26 pm
by Bernie2015
Hi Mark,
sorry I havent been down to the garage recently but just pulled a washer off the shelf that fitted - no specific size hope that helps.
