Upper steering column
Bernie2015
#1 Upper steering column
Post by Bernie2015 » Sun Sep 25, 2016 8:19 am
Hi All, I have some movement in the upper steering column on my series 2/ 2+2 and have bought a steering column bearing kit from SNG Barratt part number SBS1005. Does any one have advice on the best way to replace these bearings and if it is a complicated job. Many thanks
Bernie 1966 S1 OTS
1954Etype
#2 Re: Upper steering column
Post by 1954Etype » Sun Sep 25, 2016 8:37 am
Its not a difficult job but needs removal of the upper column. I suspect you will find the column needs reshimming to remove the play. Don't make it too tight though as the steering becomes stiff.
Angus 67 FHC 1E33656
61 OTS 875047
Bernie2015
#3 Re: Upper steering column
Post by Bernie2015 » Mon Sep 26, 2016 12:45 pm
Thanks any pointers on re shimming?
Bernie 1966 S1 OTS
1954Etype
#4 Re: Upper steering column
Post by 1954Etype » Mon Sep 26, 2016 5:32 pm
Hmmm. The factory used a wavy washer which acted as a spring to keep the tension on the bearings. It isn't possible to remove all play without this. Assuming you do have it, quite simply add remove shims, fit the circlip and see if the column turns freely with no play discernable. Obviously, if there is play, add shims if the column is too tight, remove. When you start the job it should become apparent. Don't forget to clean and grease the bearings first.
61 OTS 875047
Bernie2015
#5 Re: Upper steering column
Post by Bernie2015 » Wed Sep 28, 2016 9:46 am
Thats great thanks for the info
Bernie 1966 S1 OTS
#6 Re: Upper steering column
Post by politeperson » Wed Sep 28, 2016 6:04 pm
Yes. I had exactly this issue. The column comes out in 10 minutes if you separate the clamp.
My taper bearings were fine, however the wavy washer was in pieces.
It was not listed on SNG so I had to improvise.
With a new wavy washer the taper bearings seated properly and the up and down movement all but vanished.
KingRichard
Netherlands
#7 Re: Upper steering column
Post by KingRichard » Thu Sep 29, 2016 10:12 am
I also bought this kit from SNG, but it is not a replacement of the original bearings. It are 4 conical shaped brass and metal rings that act as bearings. I was very confused how to use it, and contacted SNG about is. Sadly didn't helped me much. Their comment was, it should be installed by a proper mechanic, because it needs to be made to fit.
I end up with not using the kit at all. Sadly couldn't return it because I partly used/installed one brass bearing in the column and therefore had some scratches when removing it.
My wavy washer was also broken. I fiixed this by using normal shims until their was just a little play. I cleaned the original delicate bearings and greased them. Column is as new.
Lesson learned. Be very sceptic at repair- rebuildkits from the usuals. In this case it was a waste of money for me.
Bernie2015 wrote:Hi All, I have some movement in the upper steering column on my series 2/ 2+2 and have bought a steering column bearing kit from SNG Barratt part number SBS1005. Does any one have advice on the best way to replace these bearings and if it is a complicated job. Many thanks
E-type series 2 2+2 RHD 1969
david muir
Scotland
#8 Re: Upper steering column
Post by david muir » Thu Sep 29, 2016 10:27 am
Does the series 1 3.8 have the 'wavy washer'?.........don't remember seeing such a beast when I replaced the upper column bushes (manual & parts book too small to make out!).
1964 3.8 FHC
1966FHC
#9 Re: Upper steering column
Post by 1966FHC » Fri Sep 30, 2016 3:03 pm
How did you drop steering down ? Any pics ? Can pics be attached and shown in posts ?
Patrick
4.2 '66 FHC
Thanks,
Patrick
4.2 '66 FHC
#10 Re: Upper steering column
Post by christopher storey » Fri Sep 30, 2016 6:14 pm
Bernie : IIRC the S2 has a different arrangement from the earlier cars with plastic bushes rather than the earlier metal ones. I don't know if there is a bellville washer on these, but I suspect not . You need to ensure that you have the correct type for your car
KingRichard
Netherlands
#11 Re: Upper steering column
Post by KingRichard » Sat Oct 01, 2016 5:14 pm
Here are some pics. One is my steering column, other the kit from SNG and original bearings.
Bernie2015
#12 Re: Upper steering column
Post by Bernie2015 » Fri Oct 21, 2016 1:05 pm
I got them to do it at the garage as it looked too hard for me so sorry no photos. They replaced the bearings which seemed to do the trick.
Bernie 1966 S1 OTS
Bernie2015
#13 Re: Upper steering column
Post by Bernie2015 » Fri Oct 21, 2016 1:17 pm
Thanks guys but I decided to let a garage do it in the end so sorry no pics for it.
Bernie 1966 S1 OTS
