Quaterlight glas seal
Quattrofrank
Norway
#1 Quaterlight glas seal
Post by Quattrofrank » Sun Aug 14, 2016 5:13 pm
I`m going to get the chrome rechromed so I had to take apart the quater light. There is some sort of rubber seal around the window that is not in good shape so it needs to be replaced.
Anyone know what the name for this part is and where I can get it?
JagWaugh
Switzerland
#2 Re: Quaterlight glas seal
Post by JagWaugh » Sun Aug 14, 2016 6:44 pm
Frank,
Oddly it isn't called out in the parts book. On the Saloons it is, the material is called "Everseal". Ask at a car glass place, you want something a bit stiffer than the usual non hardening sealer.
Andrew
Quattrofrank
Norway
#3 Re: Quaterlight glas seal
Post by Quattrofrank » Tue Sep 13, 2016 3:37 pm
Does anyone have an idea on where to source this?
Or what do people normally do when rechroming and changing glas?
My measurements indicates that the everseal strip is 2mm thick and 12mm wide. I have not been sucsessful in finding everseal in that thickness or width.
The width can probably be cutted correctly but the thickness is an issue.
Apreciate advise
JagWaugh
Switzerland
#4 Re: Quaterlight glas seal
Post by JagWaugh » Tue Sep 13, 2016 5:52 pm
Another name for it is "Glass setting tape", try googling that.
Here is one hit:
https://www.bobdrake.com/Categories7.as ... ettingtape
Quattrofrank
Norway
#5 Re: Quaterlight glas seal
Post by Quattrofrank » Tue Sep 13, 2016 7:05 pm
Andrew
Thank you, glass setting tape gave better results.
Ordered a set from ebay now, even found 5/64" and I belive that is almost 2mm :)
JagWaugh
Switzerland
#6 Re: Quaterlight glas seal
Post by JagWaugh » Tue Sep 13, 2016 7:42 pm
No problem. Sorry I didn't think of the other term earlier. I have lived in a German speaking world long enough now that much of my English technical vocabulary has disappeared.
