#1 All Synchro Gearbox Leak Saga Continuation
Posted: Fri Sep 16, 2016 9:39 am
So after thinking that my oil leak was solved, it isnt.
I found the speedo drive was loose, but tightening it up has not cured the problem.
Oil dripping onto the centre exhaust boxes.
So, 15 minutes later, after the seats carpets, centre console, radio console and gearboxc cover are removed I am looking at this and this.
Oil appears to be coming around the selector rods and or the gasket at the rear of the cover.
I assume the selector rod "O" rings have failed and the whole top mechanism has to be dissembled to replace them. Anyone know?
The shift was nice. I cannot see any adjustments.
New o rings and top gasket ordered from SNG lets hope this cures it.
I have just sucked out the thin Redline oil and replaced it with thicker EP90 so that might help too.
Nice and easy to tip in in with the top off and the level indicator is easily visible.
