#1 Which clutch cyl do I have and need ?
Posted: Wed Sep 21, 2016 9:42 pm
Hi guys,
I am finally about to order a clutch slave cyl.
The car is a 4.2 S1 2+2, March 1966.
On the car I found a 95 mm long cylinder, Lockheed (?) no. 3232-6480.
SNG lists a part no. C24145 as correct:
http://www.sngbarratt.com/ProductDetail ... f6aaf7&l=7
Then, using google, I found David Manners to list C29801 as an alternative part:
http://www.jagspares.co.uk/Manners/part ... =C24145%23
Getting back to SNG, they do list C29801 as well, showing 95 mm in the description, but they say it is for other E-Types then my 2+2 (the 2+2 is not shown in the list).
I do have found an adjustable rod, but IIRC no spring (not sure, say 90%).
I have fitted the modern smaller diaphragm clutch (had to use the smaller set of holes on the flywheel, it came with both sets of holes).
What should I do ?
Carsten
What should I do ?
Carsten
