#1 Stromberg to SU Carbs breather
Posted: Mon Sep 26, 2016 2:04 pm
by Marcus2571
Having changed from Stromberg to SU carbs is there any need to change the crankcase breather pipe on the engine? My car currently discharges downwards to atmosphere.
I note other cars fitted with SU's are piped back into the air cleaner where the crankcase emissions form part of the inlet fuel mixture.
Thanks,
#2 Re: Stromberg to SU Carbs breather
Posted: Mon Sep 26, 2016 5:21 pm
by JagWaugh
Where did it go before? (I don't know the Stromberg cars)
If the air cleaner has a connection already then I would go with that. I would probably install a puke tank rather than starting to braze pipes into the air cleaner housing.
Andrew
#3 Re: Stromberg to SU Carbs breather
Posted: Tue Sep 27, 2016 10:24 am
by Marcus2571
Stromberg went to atmosphere I believe.
Just wondering if I'm getting the most out of the new SU's and could cause other performance issues?
#4 Re: Stromberg to SU Carbs breather
Posted: Tue Sep 27, 2016 10:51 am
by mark10337
Crankcase breather on an S2 goes to the air intake box on the top between the carburetor connections. That is the same for SU or Stromberg. The pipe route and position can be different depending on the setup SU/Stromberg and the Engine Variation 1/2/3
#5 Re: Stromberg to SU Carbs breather
Posted: Tue Sep 27, 2016 10:57 am
by Marcus2571
Thanks Mark - mine currently goes to atmosphere following a change from LHD to RHD and from Stromberg to SU.
Should I look to have it connected back to the air filter?
#6 Re: Stromberg to SU Carbs breather
Posted: Tue Sep 27, 2016 11:02 am
Hi Mark.....disconnected mine from tne air intake and blocked up the hole....didnt like the oily mess going into tne carbs....i know quite a few who just discharge under the car or go a small catch tank....just make sure the engine breaths....take of the braather and clean ouf the mesh
#7 Re: Stromberg to SU Carbs breather
Posted: Tue Sep 27, 2016 11:10 am
by Marcus2571
Thanks Steve, did you notice anything different in the engine when you disconnected the breather?
#8 Re: Stromberg to SU Carbs breather
Posted: Tue Sep 27, 2016 11:17 am
Yes...no more oily mess going into the carbs
as far as im aware no affect on performance...im sure someone will come on and disagree
