There are a mismatch in size and shape between the water jackets in the block and the head gasket. It is oval in the block and cylinder head and small round in the gasket. And the water holes in the gasket does not have the same diameter on both sides, despite the holes in the block are the same size.
Is it wrong gasket? The water flow will for sure be reduced.
Its an old asbestos gasket.
