So now the engine is back in and most things are hooked up. I'm trying to bleed the clutch system and I just can't seem to get the fluid to flow through the lines. The reservoir is full of fluid. All of the clutch lines are connected and not leaking. I have tried pumping the clutch pedal and it is soft all of the way to the floor, no pressure at all. I have left the bleed nipple open to try to gravity bleed the lines and no luck. I have also tried a vacuum type bleeder (Mityvac) with no success.
What am I doing wrong?
Please help!
