#1 steering rack removal
Posted: Tue Nov 01, 2016 7:16 pm
by spotdoc67
I have a LHD 1969 FHC e type
it has just gone through the MOT with an advisory of excessive play in the steering rack,
my question is...what is involved in replacing the old rack?
My practical skills are OK.
Are there any good pictorial guides around?
Also, where should I look for a replacement rack or should I get the old one refurbished
thanks
Tom
#2 Re: steering rack removal
Posted: Tue Nov 01, 2016 7:43 pm
Before removing the rack have a good look and see exactly where the play is as it may not be in the rack itself.
There are 2 splined fittings top and bottom of the steering column that have uni joints in them and these can contribute greatly to movement.
#3 Re: steering rack removal
Posted: Tue Nov 01, 2016 8:44 pm
Hi Tom.....as well at what Andrew has said the steering rack is attaceh to the front picture frame by 2 mountings ..check them out, 2 metal plates with rubber inbetween......do you have a Jag service manusl....lots of info in there on the steering rack
#4 Re: steering rack removal
Posted: Wed Nov 02, 2016 12:41 pm
by spotdoc67
thanks
there is play in the rack itself which is most obvious on the passenger side. I'm guessing that it could be the bush in the rack on that side that is worn.
What is the best way to get the rack out.
Does the rad need to be removed or can you slide it out once the steering column is pulled up?
Tom
#5 Re: steering rack removal
Posted: Wed Nov 02, 2016 12:47 pm
You can get the rack out with the radiator in; a bit of a fiddle and easier with 2 people.
#6 Re: steering rack removal
Posted: Wed Nov 02, 2016 5:09 pm
by chrisfell
spotdoc67 wrote:thanks
Tom
Hmmmmm.... Sounds familiar.
Before ripping the rack out, just check something.
Grab the passenger side steering control arm firmly and yank it up and down.
If you can detect (hear or feel) play at the steering rack end, loosen the rubber gaitor and slide it down the control arm exposing the ball and socket at the end of the rack.
Repeat the yanking action, this time feeling where the play actually is.
If it is the ball joint and not the rack, you can adjust the play out.
Check the manual for this process.
Cost, one tab washer and a few moments after to check wheel alignment.
#7 Re: steering rack removal
Posted: Wed Nov 02, 2016 11:25 pm
Yes, what Chris said. This might be an easy fix for you if all the movement is at one end.
#8 Re: steering rack removal
Posted: Wed Sep 13, 2017 9:33 am
by spotdoc67
Hello again
sorry for the long delay in this thread
I've been sitting on this for a while :oops:
MOT is due again and I've had a look at the problem today
the play is definitely in the rack itself and I guess it must be the tube bush that has failed.
Is it possible to replace these bushes with the rack in place or will the rack need to come out for repair?
thanks
Tom
#9 Re: steering rack removal
Posted: Wed Sep 13, 2017 10:06 am
Nope you'll need to take it out.
#10 Re: steering rack removal
Posted: Wed Sep 13, 2017 9:19 pm
by ETTony
Tom, you have a PM
