Any idea what's going on here?
Ian Cooke
#1 Any idea what's going on here?
Post by Ian Cooke » Sun Nov 27, 2016 5:37 pm
Some advice please.
I am trying to remove the switch panel from series my 2 to repair / replace some of the switches. I have removed the four retuning screws but it won't budge because there is a piece of metal and a dollop of glue holding it in place - see photo.
Any idea why this would have been glued in place - possibly a broken switch?
Ian
Ian Cooke
1969 S2 FHC in Old English White
#2 Re: Any idea what's going on here?
Post by 1954Etype » Sun Nov 27, 2016 6:15 pm
Probably the plastic mounting panel for the switches broken. You can buy new from SNG.
#3 Re: Any idea what's going on here?
Post by cactusman » Sun Nov 27, 2016 6:47 pm
A previous "fix" with araldite. If you plan on replacement then a certain amount of chiseling to prize out the old one may be needed.
Ian Cooke
#4 Re: Any idea what's going on here?
Post by Ian Cooke » Sun Nov 27, 2016 9:03 pm
Thanks Angus and Julian
Should the switches come out without removing the mounting panel?
Ian Cooke
Tony
#5 Re: Any idea what's going on here?
Post by Tony » Sun Nov 27, 2016 11:17 pm
From what I can see the switch is fine, it is the end of the slot that the switch sits in has broken and a bit of what looks like metal has been glued in. It looks like you can remove the switch by pressing in the tabs at the ends of the switch and pushing it out through the front of the panel,after removing the wire connections. Then again I could be wrong
Tony (E typed)
Tony
#6 Re: Any idea what's going on here?
Post by cactusman » Mon Nov 28, 2016 7:40 am
I reckon Tony is right. Glue is not on the switch so it should pop out if the tab is pushed in far enough.
Nickleback
#7 Re: Any idea what's going on here?
Post by Nickleback » Mon Nov 28, 2016 9:08 am
Agreed, but Ian dont forget there are two clips to be released, the other one is on the far blind side
Mike,
1970 S2 FHC 2R28165
Ian Cooke
#8 Re: Any idea what's going on here?
Post by Ian Cooke » Mon Nov 28, 2016 4:46 pm
Thanks Guys that's very helpful. I'll give it a go.
Ian
Ian Cooke
