Hi all am I right in thinking that the front suspension uprights are not handed. I've looked at mine and can't tell them apart ???
Cheers for any ideas
.Darren
Front suspension uprights/ stub axle carrier
dal2.0litrefrogeye
Topic author - Posts: 1090
#1 Front suspension uprights/ stub axle carrier
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#2 Re: Front suspension uprights/ stub axle carrier
Have a look at the parts lists, SI, 4.2 lists c.19224/1 x2 (i.e. they are not handed)
Having said that, I still prefer to mark everything I take off and put it back on the same side it was on.
dal2.0litrefrogeye
#3 Re: Front suspension uprights/ stub axle carrier
Hi thanks for replies. Yes I mark stuff too but where I had it all blasted and then zinc coated I'll be damed of I can find them
oops
#4 Re: Front suspension uprights/ stub axle carrier
Screw a bolt in a hole on the right hand one before it goes off the the blasters.
Then you will know which one ot is when it comes back.
