Panel light bright/dim switch
Bernie2015
#1 Panel light bright/dim switch
Post by Bernie2015 » Sat Dec 10, 2016 9:50 am
Hi all, I am trying to get the correct switch for my series 2 2+2 panel dim/bright rocker switch. Does anyone know if this is a 3 position switch ie 0ff, bright and dim positions as most rocker switches seem to be only 2 positions ie on and off?
SNG have sent me a switch but it isn't correct. Any help would be much appreciated.
Bernie 1966 S1 OTS
#2 Re: Panel light bright/dim switch
Post by malcolm » Sat Dec 10, 2016 9:53 am
I have a series 2 2+2. My rocker is off, dim and bright, so 3 position. However, the positions would be better described as "off, virtually off, dim"
chrisvine
#3 Re: Panel light bright/dim switch
Post by chrisvine » Sat Dec 10, 2016 10:22 am
I though it was rather odd why you'd ever want an off position for the panel lights. If it's dark enough to need the headlights on then you'd always want the dash illuminated, as all modern vehicles do. David explained the reason it's three way:
viewtopic.php?f=3&t=3891&p26267
1969 S2 OTS, Elise S1
JagWaugh
Switzerland
#4 Re: Panel light bright/dim switch
Post by JagWaugh » Sat Dec 10, 2016 10:37 am
malcolm wrote:I have a series 2 2+2. My rocker is off, dim and bright, so 3 position. However, the positions would be better described as "off, virtually off, dim"
Depending on the condition of your Generator/alternator and associated voltage regulator, the proper names for the 3 positions are either "Dim, Flicker, Off" or "Smoke, Smoulder, Burn"
64etype
#5 Re: Panel light bright/dim switch
Post by 64etype » Sat Dec 10, 2016 12:43 pm
I rewired these lights to the main lighting switch thereby freeing up that panel switch position for something more useful.
Eric
Bernie2015
#6 Re: Panel light bright/dim switch
Post by Bernie2015 » Sat Dec 10, 2016 5:29 pm
Many thanks all - does anyone know the actual part number as SNG dont seem to as have been sent wrong one
Bernie 1966 S1 OTS
chrisvine
#7 Re: Panel light bright/dim switch
Post by chrisvine » Sat Dec 10, 2016 5:54 pm
Hi Bernie,
The switches used appear to have changed during the production run of the S2 (at some point in 1969) although I don't know exactly when.
The earlier cars used part number C28581 (Lucas # 35825). The later cars had part number C32856 (Lucas # 39233).
Unfortunately, as you've found out, SNG have superseded both of these parts to part no 39599, which I assume is what you were sent.
Chris
Bernie2015
#8 Re: Panel light bright/dim switch
Post by Bernie2015 » Sun Dec 11, 2016 10:18 am
Thanks Chris that solves it for me
Bernie 1966 S1 OTS
