interior footwell upholstery
#1 interior footwell upholstery
Hi - I have a '67 series one FHC. There is a vertical piece of upholstery in the passenger compartment right below the dash, roughly 14" x 14" with sound insulation on the firewall side. It has come loose, and I am unfamiliar how to re-attach it. Any advice?
Stephen Cook, Portland Oregon
#2 Re: interior footwell upholstery
Hi, sorry I don’t know your name,
Have a look through Chris Vine a member on heres blog at the trimming section.
http://etype.chrisvine.com/category/reb ... yfittings/
Here’s one of many very useful pics.
There is also loads of info on how to fit and in which order the various trim panels.
- Attachments
- B7C2F2FE-2428-4D0E-B673-71A3CB412DB8.jpeg (212.91 KiB) Viewed 3840 times
#3 Re: interior footwell upholstery
They're just glued in with contact adhesive.
#4 Re: interior footwell upholstery
I would also try and use a high temperature one as this might be why it came loose. There is quite a lot of heat from the exhaust on that side which can soften regular contact adhesive.
#5 Re: interior footwell upholstery
Thanks for the replies! High-temp adhesive ordered.
