rear brake calipers
yev
#1 rear brake calipers
Post by yev » Wed Jun 26, 2019 12:58 pm
hi guys
i have dunlops all around on my S1 2+2
they are all leaking allover .
i purchased fronts upgraded ones off SNG and they fitted fine.
cant find anything for rear thou.
if i buy pair of reconditioned Girling calipers off the ebay, would they fit my car?
#2 Re: rear brake calipers
Post by Heuer » Wed Jun 26, 2019 1:11 pm
You could get the original fronts overhauled and fit to the rear which will help keep the system in balance if the fronts are upgraded. I think Angus offers a overhaul service with s/s inserts.
yev
#3 Re: rear brake calipers
Post by yev » Wed Jun 26, 2019 1:49 pm
thank you . do you have contact for Angus?
also- would front calipers fit to the rear without any modification?
#4 Re: rear brake calipers
Post by Heuer » Wed Jun 26, 2019 3:18 pm
Yes, they will fit. You can contact Angus either by PM here (1954etype) or at his web site for email/phone: https://mossjaguar.com/index.html
Simonpfhc
#5 Re: rear brake calipers
Post by Simonpfhc » Wed Jun 26, 2019 3:38 pm
Zeus sell upgraded rears:
http://www.zeus.uk.com/index.php?dispat ... d=2&page=1
Got them on mine, beautifully made.
Cheers.
62 3.8 FHC
91 Porsche 928GT
#6 Re: rear brake calipers
Post by Heuer » Wed Jun 26, 2019 3:55 pm
Yes, Zeus are very good. I have had them all round on my FHC for the last 20 years and 50k miles with no problems. Maybe cheaper than getting originals refurbished.
mtnjag
#7 Re: rear brake calipers
Post by mtnjag » Fri Dec 13, 2019 9:53 pm
My rear caliper pistons on original S1 calipers are in need of renewal with one perhaps beyond a simple rebuild. I read here and a couple other threads that I can fit the original Dunlop front pistons to the rear. Before upgrading to Wilwood Dynalites in the front I had the original Dunlops sleeved in stainless.
They've been laying in storage for about 15years and I was wondering if this was a simple swap out or if more is involved?
Do I need to change the master cylinder for the rear if I move the 2 1/8" front pistons to the rear?
Is an adjustment of the bias needed and if so how would that be accomplished?
Layne
Car #876005, 62 OTS
#8 Re: rear brake calipers
Post by abowie » Sat Dec 14, 2019 3:47 am
If you have Willwoods on the front putting the larger original front cylinders on the rear will actually bring your brake bias back closer to what it should be with a stock system.
The cylinders will simply bolt on and replace your old ones.
I doubt you will even notice the difference in brake travel with the stock master cylinder.
So yes, this is definitely a good idea.
mtnjag
#9 Re: rear brake calipers
Post by mtnjag » Mon Dec 16, 2019 3:01 pm
Having the front pots refreshed and installing in rear calipers with TRW ceramic pads.
Thanks for info. I’ll do a quick update once done. Holidays will likely delay the process.
Layne
Car #876005, 62 OTS
