Engine Temperatures
nzmike
New Zealand
#1 Engine Temperatures
Post by nzmike » Fri Dec 27, 2019 7:11 am
Hi all, I am working through my recently acquired S1 4.2 and am interested to know what thermostats are typically fitted to S1's, and what temps the engine fans are set to come on. My car appears to have an 82 degree thermostat with the fan set to cut in at 90 - is this normal? (its an aftermarket fan). The car seems to run around 85 degrees indicated on the guage.
Michael Wood
S1 4.2 FHC
#2 Re: Engine Temperatures
Post by christopher storey » Fri Dec 27, 2019 8:37 am
I would not be dogmatic, but I believe the standard thermostats were 78 and 82, with an 88 one for very cold climates. The design running temp of the XK engine was much lower than is now fashionable at about 70 - 75 degrees C, so 85 is a bit hot
#3 Re: Engine Temperatures
Post by mgcjag » Fri Dec 27, 2019 9:05 am
Hi Michael....there has been a huge amount of discusion here on the forum re thermostats so the search function could be usefull...apart from the correct temperature do you actually have the correct stat fitted...have a look here viewtopic.php?p=65081#p65081
JCrosby
#4 Re: Engine Temperatures
Post by JCrosby » Tue Dec 31, 2019 7:09 pm
Before making any changes or modifications to anything, I'd suggest you verify the temperature first. The gauge and senders are notoriously inaccurate, perhaps not by large number of degrees but certainly within the range you're concerned about. You could spend a lot of time changing thermostat and switch only to find out the gauge was 5-10 degrees off all along.
1965 S1 4.2 OTS 1E10425
