Horn Slip Ring
abcmg68
#1 Horn Slip Ring
Post by abcmg68 » Wed Sep 18, 2019 1:35 pm
I'm in the process of rewiring a '67 4.2 Coupé. I have a purple/black wire for the horns near the steering column. I can't seem to find the horn slip ring that it should plug into. Any help would be appreciated.
Thanks.
Alan
#2 Re: Horn Slip Ring
Post by abowie » Wed Sep 18, 2019 9:33 pm
Push fit into 22. Held by 27.
Springer
Norway
#3 Re: Horn Slip Ring
Post by Springer » Sun Jan 12, 2020 4:30 pm
You may lack some parts. SNG has a set of spareparts for this I found very useful.
Restauration project of a serie 1 1963 model OTS now running proudly
Robbiee
#4 Re: Horn Slip Ring
Post by Robbiee » Sun Jan 12, 2020 6:32 pm
Andrew is correct
22 is technically not the actual slip ring but it is the contact which is spring loaded and sits on it
