Spacer location
JimH
#1 Spacer location
Post by JimH » Wed Apr 28, 2021 2:56 pm
Can someone tell me where these spacers should go. On a series 1 2+2.
67 series 1 2+2 ,68 MG midget 1st car,70 VW Dormobile type 2,3 BMW Isettas,2 Messerschmidts,
1 Heinkel Ireland,Zundapp Janus,Goggomobil Royal,Goggomobil Coupe & 7 Motorbikes
#2 Re: Spacer location
Post by Heuer » Wed Apr 28, 2021 3:27 pm
First three could be distance pieces to hold washer bottle away from bulkhead BD18957/1
Second three could be distance pieces on bolt securing cowl to radiator (you only need two) C15712
Third could be distance pieces under forward end of radiator tie bars BD25765
Fourth could be eccentric sleeve on accelerator fulcrum lever C23915
Second and third could be the other way around!
H7OB
#3 Re: Spacer location
Post by H7OB » Wed Apr 28, 2021 4:10 pm
Could the large ones be from underneath the rear end of the front seat runners?
'68 Series 1.25 2+2
#4 Re: Spacer location
Post by Heuer » Wed Apr 28, 2021 8:37 pm
On a 3.8 yes but the later 4.2 seats did not use them
H7OB
#5 Re: Spacer location
Post by H7OB » Wed Apr 28, 2021 9:32 pm
As it’s a 2+2 I understood they were for 2nd row foot clearance. Every little helps! I did away with mine as I preferred the extra headroom in the front.
'68 Series 1.25 2+2
JimH
#6 Re: Spacer location
Post by JimH » Thu Apr 29, 2021 6:12 pm
Cheers I will investigate further tomorrow
#7 Re: Spacer location
Post by PeterCrespin » Thu Apr 29, 2021 7:37 pm
JimH wrote: ↑
I can’t say for sure but the bulkhead stand-off idea sounds likely for three. The radiator cowl sounds likely too but I thought under the mushroom front seat bobbins had spacers too. If it’s a LHD car there were spacers in the bottle shield to save crushing the asbestos.
The only thing I can say with 100% certainty is there’s no d in Messerschmitt, but you’re the microcar expert, not me.
44DHR
#8 Re: Spacer location
Post by 44DHR » Fri Apr 30, 2021 8:38 am
It may not be related, but there are two “distance pieces”, part number C 24424, between the Alternator Bracket and Water Pump. They look a bit like the two as the third set.
As seen on my spare engine :-
Dave Rose
1967 Series 1 4.2 FHC
