Thanks for the link, great but they are all out of stock. I'll keep checking back to see when they are back in stock.
205 tyres
#42 Re: 205 tyres
Thanks for the info, I doubt if I drive even 500 miles a year so money wasted and certainly don't take it out in the coldgtjoey wrote: ↑Fri Feb 04, 2022 11:45 pmDave if you have the budget , THE MICHELIN XWX transforms the car to at least the 1990s!
IMHO and doing thousands and thousands of miles a year.
They are 400 a tire but .........
Pirellis are good but not great in cold and seem to flat spot till warmedup.
gtjoey1314
#43 Re: 205 tyres
Dave...vintage tyres link show as in stock...and i just put 2 in my basket on line.....Steve
#45 Re:
Only 4% smaller, within the wear range of 185's. Very little difference at normal road speeds.
Randall Botha
#46 Re: 205 tyres
Until I read this post, I was going to ask about tyre's for an S1 ... Now my head is mashed ha ha! Lots more research and considerations to do.
Technical Adviser to a
S1 2+2 4.2
1966
S1 2+2 4.2
1966
#47 Re: 205 tyres
The only remotely suitable tyres I could find in South Africa were V rated Dunlop 205/65's by Sumitomo. I had slight fouling of the bump stops & brakets on full drop. Solved by shaving the bottom sharp corner off the brackets. Also sliced the bump stops in half & turned them inside out to angle slightly inwards. Don't know if they'll miss the hub carrier on full bump though.
Randall Botha
