Brake/Clutch reservoir hoses SI 3.8
Desmo
#1 Brake/Clutch reservoir hoses SI 3.8
Post by Desmo » Sun Sep 18, 2022 6:18 pm
Hello,
I would like to replace the 3 original small reservoir botlle hoses with correct yellow sriped items. Is this hose type still available, with the characterristic yellow stripes and the correct diameters, so that the original clamps can be reused?
Thank you for your help
Danny Lee
#2 Re: Brake/Clutch reservoir hoses SI 3.8
Post by Danny Lee » Fri Sep 23, 2022 11:49 am
Use good quality brake hose and paint a stripe using tyre paint pens ( used for highlighting lettering) I used 3mm tape on the hose 3 bits in parallel then remove centre one and paint….. works a treat….. don’t forget the white on the water hoses
