Body number tags
Terry Sturgeon
#1 Body number tags
Post by Terry Sturgeon » Wed Oct 26, 2022 9:30 pm
On Oct 13th I celebrated 50 years of ownership of my '68 ots. It was a German delivery, purchased by a Canadian Air Force officer in Germany and brought back to Canada several years later. Many miles and all the years later I still enjoy long trips in the car, rally and autocross. The car had a minor rear end collision about 35 - 40 years ago and the body tag under the license plate went missing. Does anybody know if they are available in reproduction? I have the number off the plate below the fuel filter. They have reverse stamping and a square font, so it's not something that's easy to do.
'67 fhc, 67 fhc, '68 ots, '07XKR
WayneM
#2 Re: Body number tags
Post by WayneM » Wed Oct 26, 2022 11:53 pm
Older topic. I will be interested in what you find.
viewtopic.php?t=7161&highlight=body+plate
1967 E Type OTS
Geoff Allam
#3 Re: Body number tags
Post by Geoff Allam » Thu Oct 27, 2022 3:52 am
Hi Terry. You could try this vendor. The picture is of the tag he sent to me. I requested that the holes be left undrilled so that I could match the holes in my car. If I remember correctly it was made of steel but I would imagine you could request aluminum.
Geoff Allam
Harold Lang
#4 Re: Body number tags
Post by Harold Lang » Thu Oct 27, 2022 9:34 am
I'd echo Geoff's suggestion of Clarke Spares.
Harold
Robbiee
#5 Re: Body number tags
Post by Robbiee » Thu Oct 27, 2022 12:31 pm
I echo the above
Terry Sturgeon
#6 Re: Body number tags
Post by Terry Sturgeon » Thu Oct 27, 2022 8:07 pm
Thank you gentlemen. I've sent an email to ClarkSpares, just waiting for a response.
caveman
#7 Re: Body number tags
Post by caveman » Fri Oct 28, 2022 12:08 pm
https://www.ebay.co.uk/itm/255746995827 ... R6b82ueDYQ
These are from USA so may well be from same supplier.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
tim wood
#8 Re: Body number tags
Post by tim wood » Fri Oct 28, 2022 1:23 pm
I used this supplier for the tags.
We had an issue whereby the supplied tag with holes was too short to fit the original fixing points in the number plate recess. I’m certain the the bodywork is original.
New tags were required which were provided and the supplier was very good with communication etc. it was just a niggle at the time.
The provided plates were good though.
Tim
Robbiee
#9 Re: Body number tags
Post by Robbiee » Fri Oct 28, 2022 9:44 pm
I merely sent him the dimensions and position of holes
GoodManGoneBad
#10 Re: Body number tags
Post by GoodManGoneBad » Sun Apr 19, 2026 5:51 pm
I've tried these links and tried to contact the referred suppliers. No luck. Anyone have a current source for these reverse punched rear Body Number Tags?
#11 Re: Body number tags
Post by mgcjag » Sun Apr 19, 2026 6:01 pm
Fillow the link in post 2 to AJ autocraft ...Steve...unfortunatly Tod Clark in the US has passed away a while back
