Body number tags
Terry Sturgeon
Topic author - Posts: 10
#1 Body number tags
On Oct 13th I celebrated 50 years of ownership of my '68 ots. It was a German delivery, purchased by a Canadian Air Force officer in Germany and brought back to Canada several years later. Many miles and all the years later I still enjoy long trips in the car, rally and autocross. The car had a minor rear end collision about 35 - 40 years ago and the body tag under the license plate went missing. Does anybody know if they are available in reproduction? I have the number off the plate below the fuel filter. They have reverse stamping and a square font, so it's not something that's easy to do.
'67 fhc, 67 fhc, '68 ots, '07XKR
Geoff Allam
#3 Re: Body number tags
Hi Terry. You could try this vendor. The picture is of the tag he sent to me. I requested that the holes be left undrilled so that I could match the holes in my car. If I remember correctly it was made of steel but I would imagine you could request aluminum.
Geoff Allam
Harold Lang
#4 Re: Body number tags
I'd echo Geoff's suggestion of Clarke Spares.
Harold Lang 885963
Harold Lang 885963
#5 Re: Body number tags
I echo the above
Terry Sturgeon
#6 Re: Body number tags
Thank you gentlemen. I've sent an email to ClarkSpares, just waiting for a response.
#7 Re: Body number tags
https://www.ebay.co.uk/itm/255746995827 ... R6b82ueDYQ
These are from USA so may well be from same supplier.
1965 S1 4.2 FHC (early)
#8 Re: Body number tags
I used this supplier for the tags.
We had an issue whereby the supplied tag with holes was too short to fit the original fixing points in the number plate recess. I’m certain the the bodywork is original.
New tags were required which were provided and the supplier was very good with communication etc. it was just a niggle at the time.
The provided plates were good though.
Tim
Tim
#9 Re: Body number tags
I merely sent him the dimensions and position of holes
