Fitting the fuel tank
gmunro
#1 Fitting the fuel tank
Post by gmunro » Mon Mar 06, 2023 8:00 pm
Hi Gents,
I cannot find information of how the fuel tank mounting bracket and its associated reinforcement plate are actually fitted to a S1 OTS. It is obvious that the mounting bracket is fitted inside the boot but what about the reinforcing plate? Is it fitted inside the boot or is it fitted outside?
So grateful for advice and guidance as always.
Yours aye,
George :banghead:
1967 Series 1 OTS
tim wood
#2 Re: Fitting the fuel tank
Post by tim wood » Mon Mar 06, 2023 9:36 pm
It’s fitted outside to support the panel.
Easier if your rear cage is out otherwise slide your hand up .
Tim
From memory, fit the bracket after the tank is in place.
( it’s a fun job ! )
gmunro
#3 Re: Fitting the fuel tank
Post by gmunro » Tue Mar 07, 2023 8:25 am
Hi Tim,
That's what I thought so thanks very much for the confirmation. Fortunately the cage is out so it should be straight forward enough ......... after the fight to get the tank in first!
Yours aye, :thankyouyellow:
George
1967 Series 1 OTS
