Galvanic coating of the Dunlop "C" cylinders
Desmo
#1 Galvanic coating of the Dunlop "C" cylinders
Post by Desmo » Sun Aug 20, 2023 7:17 pm
Hello,
Were the cast iron Dunlop brake cylinders originally zinc or cadmium plated? During the forthcoming overhaul, I would like to restore them to their original appearance.
Thank you for your hints.
Best regards
#2 Re: Galvanic coating of the Dunlop "C" cylinders
Post by Heuer » Sun Aug 20, 2023 7:45 pm
Cadmium
cactusman
#3 Re: Galvanic coating of the Dunlop "C" cylinders
Post by cactusman » Fri Aug 25, 2023 7:47 pm
Unless you know someone in the aircraft business then cadmium plating is no longer possible (in the UK)...
Desmo
#4 Re: Galvanic coating of the Dunlop "C" cylinders
Post by Desmo » Fri Aug 25, 2023 8:45 pm
... Unfortunately.
Thank you both for your information.
Best regards
#5 Re: Galvanic coating of the Dunlop "C" cylinders
Post by Heuer » Fri Aug 25, 2023 8:45 pm
Quite a few places in the US, every street corner in India!
Very difficult in Europe although if you look east there will be places. Personally, unless it is on OBL, I would say it is not worth the trouble or expense.
CMC did an early OTS and cad plated everything, including all the handbrake parts you cannot see. Can't remember the cost but it was high.
cactusman
#6 Re: Galvanic coating of the Dunlop "C" cylinders
Post by cactusman » Sun Aug 27, 2023 7:59 am
You could get them zinc plated...it's the std replacement for cadmium where cad plating is no longer permitted (or is prohibitively expensive)..
#7 Re: Galvanic coating of the Dunlop "C" cylinders
Post by Series1 Stu » Sun Aug 27, 2023 11:07 am
Zinc plating is what you would get if you sent them away for reconditioning by a reputable supplier. If you're going to strip them yourself and send them for plating make sure your supplier is fully conversant with plating cast iron parts because of the particular pre-treatments required.
Desmo
#8 Re: Galvanic coating of the Dunlop "C" cylinders
Post by Desmo » Sun Aug 27, 2023 7:25 pm
Hello Julian, hello Stuart,
I have agreed a silver zinc plating with the workshop. The workshop is PastParts Ltd. I got 4 original used cast iron 1/8 Dunlop brake cylinders for the front axle as a possible replacement some time ago. Now that I have decided to overhaul the units belonges to the car, I will offer them for sale. It is interesting that these replacement cylinders were not cadmium-plated but merely blackened or painted black.
#9 Re: Galvanic coating of the Dunlop "C" cylinders
Post by mgcjag » Sun Aug 27, 2023 7:38 pm
If you go for zinc plating ensure that it has a passivant coat..if not the zinc will go gray and powdery...Steve
cactusman
#10 Re: Galvanic coating of the Dunlop "C" cylinders
Post by cactusman » Sun Aug 27, 2023 8:37 pm
Yes...wise word Steve...
#11 Re: Galvanic coating of the Dunlop "C" cylinders
Post by Series1 Stu » Sun Aug 27, 2023 9:56 pm
It's likely to be a clear passivate coating these days so it will be grey/silver in appearance.
