Nothingjaspercat10 wrote: ↑Fri Aug 11, 2023 4:54 pmBeen trying to get a response from him on this? Is anyone else receiving anything ?
Master Brake/ Clutch Cylinder Aluminium Tags
#41 Re: Master Brake/ Clutch Cylinder Aluminium Tags
1965 S1 4.2 FHC (early)
#42 Re: Master Brake/ Clutch Cylinder Aluminium Tags
#43 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Hi Maikel, what other numbers are on the plastic tags?
Randall Botha
#44 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Happy to share,
I am posting some pics I have taken, as you can see, one is clutch the other is brake.
Hope you can assume what is what.
clutch dated 12 62
VBM 4705 assuming
C. 19967
lower brake master dated 12 62
VBM 4706
C. 19968
assuming upper brake master dated 12 62
VBM 4707
C.19969
Maybe someone can confirm. It seems the plastic tags did have a consecutive number where then the date of inspection had been squeezed in.
clutch dated 12 62
VBM 4705 assuming
C. 19967
VBM 4706
C. 19968
VBM 4707
C.19969
#45 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Thank you Maikel, that's very useful info.
Randall Botha
#46 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I still have the original ones fitted to my brake master cylinders. The clutch one disappeared at some point and wasn't on the car when I got it.
#47 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Would be great if someone could produce a set of the plastic ones with the correct part nos. stamped into them.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#48 Re: Master Brake/ Clutch Cylinder Aluminium Tags
There is a very nice bloke on ebay that is selling the stamped aluminium tags - 1961 to early '62. He has maybe 20 sets left.
He cut these over 5 years ago and only had questions for the drawing. Please don't contact him for a drawing.
Hope I'm not breaking a forum rule David.
Keith
Keith
