Hi All
I just had to service my tach generator and in doing so found the lock plate missing (C15918) and a small gap, as pictured, between the intake manifold housing/cylinder head and the tach generator. Given the fact that the lock plate is missing, I worry that something else might not be quite right. Isn't the cam cover supposed to be sealed?
Thanks,
Dom
Tach Generator Gap?
#2 Re: Tach Generator Gap?
There is an O ring on the cylindrical part of the TG that provides the seal to the cam cover/cyl head. There is no gasket on the large flat face of the TG. No lock plate is not a big deal, as many use low strength Loctite or similar on the three retaining screws.
Modifying a ball end hex key by heating and bending to form a short legged "L" on the ball end and using socket head screws (if not fitted already) makes the removal and tightening of those retaining screws much easier.
#3 Re: Tach Generator Gap?
Many thanks, Steve. Reassuring.
1966 s1 FHC 4.2
#4 Re: Tach Generator Gap?
The locking plate is probably missing because it can be very tricky to fit.
I glue it to the tach generator with a bit of super glue before it fit the generator.
#5 Re: Tach Generator Gap?
My engine doesn't have a locking plate, and hasn't for the last 20nyears and over 80,000 miles. Not sure it was ever needed. The securing Allen head screws have shakeproof washers.
